TwinTurbo.NET: Nissan 300ZX forum - Ok, thanks. I will check the oil and coolant for...
Z-line
on January 04, 2015 at 5:41 PM
You should run a Leakdown test
posted by Stanky
on January 04, 2015 at 02:06 AM
HG issue. I didn't notice any abnormalities the last time I took a look. So the marks should be off if the TB skipped?
compression test results on a TT engine
Z-line
01:42:19 01/04/15
Stanky
02:06:20 01/04/15
Ok, thanks. I will check the oil and coolant for... -
Z-line
17:41:01 01/04/15
Do you own a coolant pressure tester?
Stanky
20:38:34 01/04/15
I will go ahead and rent one and report back, Thx (n/m)
Z-line
21:06:54 01/04/15
The TB marks will not be aligned. You will have to align
SammybTT(TN)
13:12:30 01/05/15
Yes at TDC for #1 at compression stroke all the dots >>
ZUL8TR
12:20:39 01/06/15
do what stanky said
FrozTTy
11:08:57 01/04/15
good advice above
SammybTT(TN)
13:32:29 01/05/15
